Home > Basic Circuits >General Knowledge > LM338 pin diagram and function, LM338 schematic diagram, LM338 application circuit diagram
Source: InternetPublisher:qoistoochee128 Keywords: Three-terminal voltage regulator LM388 Updated: 2025/03/04
    The LM388 is a variable DC power supply component, a three-terminal adjustable voltage regulator IC in a TO-220 package that provides a stable output voltage.
    For example, if its output is set to 5V, it will provide a stable 5V output regardless of whether the input voltage fluctuates, but the input voltage must be 2V to 3V higher than the output voltage.
    The configuration of LM338 IC has a pinout of three terminals:
    Input pin: receives DC signal.
    Adjust Pin: Sets/adjusts the desired output voltage.
    Output pin: Generates output voltage, which is filtered by the filter capacitor and sent to the output end of the circuit.
LM338 Schematic Diagram
    The LM338 has many transistors, Zener diodes, resistors and capacitors inside. Below is the schematic diagram of the LM338.
LM338 application circuit diagram (I)
    The circuit below produces an output voltage that can be equal to the input voltage, but the current varies well and cannot exceed 5 A. Resistor R1 is precisely matched to maintain a safe 5A limit current limit that can be obtained from the circuit.
LM338 application circuit diagram (II)
    The circuit below shows a very simple design where a phototransistor replaces a resistor which is used as the component to regulate the output voltage.
LM338 application circuit diagram (III)
    The following circuit shows another circuit with a current limit of 10A, which means that the output can be made suitable for high current rated loads and the voltage can be adjusted as usual via potentiometer R2.
