LM317HV circuit diagram based on 3A switching regulator
Source: InternetPublisher:toothache Keywords: switching regulator Updated: 2024/01/04
The circuit diagram below is a simple and inexpensive switching regulator capable of providing an adjustable voltage output range of 1.8V to 32V and a quiescent current of 3A. This voltage regulator uses LM317HV adjustable voltage stabilizing IC and 2N3792 power PNP transistor.
The LM317HV is an adjustable 3-terminal positive voltage regulator capable of delivering over 1.5A over an output range of 1.2V to 57V. This electronic component is very easy to use, requiring only two external resistors to set the output voltage. Additionally, both line and load regulation are superior to standard fixed regulators. Additionally, the LM317HV comes in a standard transistor package for easy installation and handling.
LM317HV features:
Adjustable output as low as 1.2V
Specified 1.5A output current
Line regulation is typically 0.01%/V
Load regulation is typically 0.1%
Current limit constant changes with temperature
100% electrical aging
No need to store many voltages
Standard 3-pin transistor package
80dB ripple suppression
Output short circuit protection
P+? Product Enhancement Testing
Circuit notes:
C1 and C4 must be solid tantalum capacitor types for best output quality.
L1: CORE-ARNOLDA.254168.260 transfer
- How does a step-down switching regulator use a series transistor or a power MOSFET?
- How to enhance power and signal integrity through low noise?
- TL431 functional pin diagram, DC linear regulated power supply solution based on TL431
- 220V Remote Load Monitor
- Simple and practical LED lamp driving circuit
- Parallel DC regulated power supply circuit diagram
- Dynamic power supply for power amplifier controlled by thyristor
- CNC regulated power supply production
- LM317 regulated power supply
- Converting a lithium battery charging board into a constant voltage and current charger
- Excellent performance household inverter power supply circuit
- 300A-18V three-phase thyristor voltage regulating electrolytic power supply circuit
- Simple dual-channel variable DC power supply circuit
- CF1 (CF2) DC power supply circuit
- Super Class A power amplifier power circuit
- Boost switching regulator circuit using 555
- Low power switching regulator circuit
- Boost switching regulator composed of MC34063
- MC34063 and transistor form a high current boost switching regulator
- Switching regulator circuit diagram composed of SG3524
