Gantry planer
Source: InternetPublisher:两手空空 Keywords: Machine tools BSP electric motors stepless speed regulation Updated: 2020/08/19
It is particularly suitable for processing large and long and narrow mechanical parts, such as machine tool beds, boxes, guide rails, etc.
Taking the B20lOA gantry planer as an example, it requires 13 electric motors . Many movements such as the movement of the knife, the advancement, retraction, and lifting of the tool; the relaxation and clamping of the beam
, the rise and fall, and the stepping and retreating of the worktable are all completed by the organic cooperation of many motors and electrical components. Its main
drag system has higher requirements. It not only requires sufficient cutting power and a large speed adjustment range, but also needs to be able to realize automatic speed
cycle and adjustment as required. The appearance of the boring machine is shown in Figure 2-lOa.
(1) The production process of Yuanmen planer has the following requirements for the electrical control system:
1) A wide speed range is required. The speed adjustment range is required to be 20; 1 (including 1-speed mechanical speed change). The low speed range of each segment is 6~
60m/min, and the high speed speed range is 90m/min~90m/min to achieve electrical stepless speed adjustment .
- How solar cells work, some unique designs of solar cells
- DIY an electromagnetic glove
- Share an electronic touch organ circuit
- How to convert digital values into analog values by connecting MCP4725 with Arduino
- How to create a digital watch using YAKINDU Statechart Tools
- Electronic Rat Killer Circuit
- Production of wake-up device
- Using VPX-based PCIe systems for asynchronous clocking
- How to Design a Wireless Remote Controlled Two-Wheeled Robotic Rover Using ESP8266 and Arduino Uno
- Test and Application of Power Amplifier TDA7294
- Motor forward and reverse control wiring diagram (2)
- electromagnetic field sensor
- Agricultural spraying and insecticide control circuit
- Biogas concentration detection line
- Integrated synchronous detector composed of analog multiplier MC1596
- Simple AGC circuit in transistor radio
- Common emitter-common base wideband amplifier circuit composed of F733 integrated amplifier
- common emitter amplifier circuit
- Second-order active band-stop filter circuit
- Voltage-controlled voltage source second-order active low-pass filter circuit
