PIC frequency meter and voltmeter
Source: InternetPublisher:SrpCPccfym Keywords: Frequency meter voltmeter Updated: 2026/02/27
PIC frequency meter/voltmeter
Frequency measurements up to 50MHz
Power supply voltage measurement range: 0.0 V - 25.5 V
The input voltage at both analog input terminals is measured and simultaneously displayed as a bar graph (PWR/SWR or S) indicator.
The input sensitivity can be selected between 0.25V, 0.5V, 1.0V and 2.0V to achieve maximum bar graph indication.
This is the successor to the PIC16C71 4-digit LED frequency meter and voltmeter.
Some hard-to-find parts used in previous versions have been omitted because they have been discontinued for some time.
The earlier PIC16C71 was replaced by the 28-pin device PIC16F876.
The latter can drive a 4-digit LED display in multiplexed mode, simultaneously measure frequency and power supply voltage, and process two analog inputs to display the SWR/PWR signal strength in a bar graph format.
Since it is built into the PIC16F876, no external digital tube driver chip or external data EEPROM is needed.
The reduced number of chips used also makes the counter smaller than its predecessor.
- PIC18F2445 USB Experimental I/O Board
- AVR Thermometer TCN77
- USB data acquisition based on PIC18F4550
- How to build a PICKit3 programming circuit with a PIC microcontroller?
- What is the mechanism of microcontroller latch-up?
- How does MCU communicate with external peripherals using serial communication?
- Make an alcohol tester based on 8051 microcontroller
- How to connect ADC to 8051 microcontroller?
- How to use the GPS module of STM32F103C8 to obtain location coordinates
- Interface circuit between intelligent temperature sensor TCN75 with two-wire serial interface and 89C51 single-chip microcomputer
- DC voltmeter and ammeter connection circuit
- The voltmeter is connected to circuit a through a voltage transformer or commutation switch
- Grain moisture detection circuit
- Simple DC voltmeter circuit
- Multi-range voltmeter circuit with field effect transistor output
- Automatic voltmeter circuit with impedance converter
- Bar graph voltmeter
- Negative feedback voltmeter
- Four and a half digit LCD digital display voltmeter circuit
- Multifunctional frequency counting circuit
京公网安备 11010802033920号
