Active low frequency distortion correction circuit
Source: InternetPublisher:elleny Keywords: Low frequency BSP speakers Updated: 2020/08/24
The active low-frequency distortion correction circuit is an accessory of the German CAN fflN bookshelf box FONUMSC-3. Due to the use of
active low-frequency distortion correction technology (sc technology), the low-frequency response of this two-way inverted bookshelf box with an 8-inch mid-bass unit and a volume of only 22 liters
is expanded to 22№. This circuit is connected before the power amplifier.
Figure 9-70 is a channel of the active low-frequency distortion correction circuit. Figure 9-71 shows its amplitude-frequency and phase-frequency characteristics.
As can be seen from the figure, this is a high-Q high-pass filter characteristic with a passband gain of 1, a
resonance peak of 14.4dB at 35.8°C, and an attenuation slope of approximately 30dB per octave. The
inverted speaker can be equivalent to a high-pass filter, with an attenuation slope of up to 24 per octave. As long as the compensation
circuit has an appropriate Q value and the resonant frequency is appropriately designed, the low frequency of the speaker can be well compensated. response, making the synthesized
sound pressure frequency response curve smoothly extend to ultra-low levels. This is the essence of SC technology. SC technology performs low-frequency compensation on
inverted speakers with large attenuation slopes, so that the entire speaker system forms an 8th-order high-pass system.
- Using TDA2822 to do direct coupler output experiment
- Making a Simple Tube FM Radio
- Homemade multi-sound effects sound system
- Minimum output noise/reduced output power circuit using LM4910
- Stereo phono amplifier circuit with bass control composed of LM1877
- 1OW audio power amplifier circuit using UPC1238
- Single power supply audio power amplifier circuit composed of LM3875
- LM4820-6 audio power amplifier circuit
- Tube single-ended class A 300B power amplifier circuit
- American Grado RA1 headphone amplifier
- Excellent performance household inverter power supply circuit
- stuttering correction circuit
- High-efficiency speaker circuit for rural stage
- Rural fish farming control circuit
- Rural vegetable greenhouse lighting circuit
- Double gate field effect transistor high frequency amplifier circuit
- Voltage series negative feedback amplifier circuit
- Voltage-controlled voltage source second-order active low-pass filter circuit
- Three primary color display circuit
- Sine wave signal generator circuit
