Improved circuit to suppress the influence of power supply voltage waveform (a)
Source: InternetPublisher:D先生 Keywords: Improve circuit supply voltage RCS diode Updated: 2021/01/22
The above shortcomings can be overcome by changing VT3 in Figure 8-21(a) and (b) respectively
. In Figure 801, when the V-voltage decreases, the constant current value of VT3 also decreases, that is, IDI.Inz decreases,
so Jrcs also decreases, so VTl;: the voltage drop R on the collector resistor Rcs . . Ia also decreases. This offsets
the change in output potential caused by the decrease in V1. Similarly, when V increases, Ra,. Jf. also increased. Therefore, the power supply voltage
fluctuation characteristics
of the circuit shown in Figure 8-21 are better than those in Figure 8-20. The diode VD in Figure 8-21(a) is used to compensate
for the temperature drift of VTi.
- What is a Half Wave Rectifier? Working Principle of a Half Wave Rectifier
- What is the relationship between capacitance and impedance in an AC circuit? How do you calculate the impedance of a capacitor?
- What are the main types of resistors? Detailed explanation of the functions and uses of resistors
- FPGA Features and Architecture
- Causes and solutions for noise in digital Class D amplifiers
- Capacitance detection circuit configuration, how to deal with low frequency and high frequency noise?
- Transfer characteristics of BJT, how to apply Shockley equation?
- TL494 pin functions/configuration/ratings/operating conditions/layout diagram
- Ceramic filter structure/working principle/characteristics/application
- Summary of knowledge points of multiplexer
- Schottky and Silicon Carbide Diode Analysis
- Wireless microphone circuit
- Analysis of various power supply filter circuits
- RF sniffer circuit
- Electronic frostbite treatment device circuit diagram
- Diode IN148 temperature measurement circuit
- Tuning circuit composed of TA7335P
- Incandescent lamp step-down circuit
- Automatic water supply control circuit 2 for simultaneous monitoring of water tower and reservoir
- Fast response circuit a when controlled by transistor
