Dynamic scanning spectrum display
Source: InternetPublisher:石榴姐 Keywords: Monitor spectrum display BSP Updated: 2020/09/15
As shown, it
consists of band-pass filter, rectifier integration circuit, dynamic scanning circuit, comparison amplifier circuit and LED matrix.
The input part of the circuit uses 2 four-op amp circuits to form 8 band-pass filters. The input full-frequency signal is divided
into eight segments. It sets the center frequency of the eight segments based on the relationship between 2 and 4 octaves. Set at 32№, 76Hz, 180№,
430Hz, 1.05kHz, 2-SkHz, 6kHz, and 14.5kHz.
Dioi~D1.06, R40l~‰¨‰l~ island are connected to the output ends of each band-pass filter.
The rectifier integration circuit of each frequency band is used to convert the amplitude of the AC signal output by each filter into the level of DC level. After selection by
the analog switch, it is sent to the DC level comparator and drives the LEI through the matrix circuit) Luminous display.
IC6, Scorpion and R50l-Rsos form a level comparator. Among them, Rsoi~R50a form an eight-level voltage divider.
After dividing the 12V DC voltage according to a certain proportion, it is added to the inverting terminals of eight voltage comparators as the reference voltage of each comparator
. It can be seen from the figure that these 8 reference voltages are higher than one from bottom to top. The DC signal voltage sent out after being gated by the analog switch
is simultaneously added to the non-inverting input A terminal of each voltage comparator (IC6, IC) for
comparison with its respective reference voltage. When the input DC signal voltage is higher, then From the bottom up (that is, from IC7d to ICr5a), the more interesting comparators
output high levels and light up the corresponding LEDs. According to the number of lit LEDs,
the strength of the signal in that frequency range can be known. R600 - R608 in the picture are current limiting resistors and are used to protect the D of the operational amplifier.
- Make the most beautiful sound with the least money
- Preamplifier made of 6P15 tube
- 18-inch large speaker
- The production of 6P14 small tube amplifier
- A simple and practical tube amplifier
- Electronic bird repeller for crops
- Class A power amplifier circuit with an output power of 18W
- Single power supply audio power amplifier circuit composed of LM3875
- Differential input audio amplifier circuit composed of LM4904
- Active power amplifier circuit composed of TDA2003
- strain sensor
- stuttering correction circuit
- Physiotherapy ventilator circuit
- Crop anti-frost circuit
- Chicken supplementary light to increase egg production rate circuit
- Rural fish farming control circuit
- Agricultural spraying and insecticide control circuit
- AC voltmeter
- Domestic KD8041 integrated phase locked loop
- Diode balanced amplitude modulation circuit
