30W power amplifier circuit
Source: InternetPublisher:王达业 Keywords: Power amplifier circuit BSP bias circuit NE5532 Updated: 2020/06/15
This circuit is a power amplifier circuit that uses field effect transistors as output . The operational amplifier NE5532 is powered by
a ±15V power supply, and its output is amplified by a first-level voltage to drive the FET output stage. The voltage of the bias circuit
of the output stage is taken from the ±15V input to the pre-stage, and
is supplied to the bias circuit after being stabilized by VT3 and VT4. The positive and negative voltage regulator tubes VT3 and VT4 use two LEDs as voltage references. The LEDs not only have good voltage characteristics, but can also be used as an indication of the working status of the circuit. Using this power supply circuit not only becomes a constant voltage bias
with excellent performance circuit , and it can be used as a constant current source load of the pre-stage to increase the gain of the output stage.
Vn and VTz form a push-pull output push stage, which is also a set of common emitter circuits with voltage amplification capabilities.
Vr7 and VTs form the overload protection circuit of the output tube.
ICIb (lf/ NE5532 ) and so on form a zero-point servo circuit. R23.C4 and ‰ form a negative feedback circuit.
The output stage vMOS tube uses 2SJ115 and 2SK405. 0 can also use IRF9130 and IRF130. The parameters are:
transconductance is 4, withstand voltage loOvPCM=75W, Iau=9A.
During debugging, just measure the voltage drop on the 0.22fl resistor to be 40~50mV.
- Echo Dot speaker intelligent control system solution
- TDA2009A power amplifier circuit
- Experiment of 2-in-1 single-ended Class A tube amplifier
- Toy electronic chicken
- LM4766 Dual 40W+40W Power Amplifier
- The fun of making ISD1820 voice recording box
- Using an old tube radio to make a 6N1+6P14 tube amplifier
- Electronic bird repeller for crops
- Audio power amplifier circuit composed of LM4835/4838
- High gain audio amplifier circuit composed of LM4818
- electromagnetic field sensor
- strain sensor
- Rice mill circuit
- Farmland drainage automatic control circuit
- Series crystal oscillator
- Crabo oscillator circuit
- Inductive feedback oscillator circuit
- Double gate field effect transistor high frequency amplifier circuit
- OTL low frequency power amplifier circuit
- Wireless microphone circuit
