Internal circuit of TM2001A
Source: InternetPublisher:方世玉223 Keywords: OCL protection circuit Updated: 2020/06/21
TM2001A is an 18-pin single-in-line plastic package circuit. Its internal circuit principle is shown in Figure 2-1090. As can be seen from the figure, this circuit
is an OCL type bi-amplifier circuit. Its characteristic is that the emitter resistor of the output tube is connected outside (through 7 , 8 pins and 11, 12
pins), which not only improves the reliability of the circuit operation, but also allows the fork to be easily connected to the protection circuit through this resistor .
- How to use the Arduino tone function to play a melody on a piezo buzzer or speaker
- LM4766 Dual 40W+40W Power Amplifier
- Preamplifier made of 6P15 tube
- Using 6P15 to create an ultra-linear push-pull amplifier
- Using Shuguang 350C tube to make tube amplifier
- Bridge output audio power amplifier circuit composed of LM1876
- LMl876 is used to assist the audio power amplifier circuit
- 2W×2 power amplifier circuit using LM1877
- LM4820-6 audio power amplifier circuit
- Active power amplifier circuit composed of TDA2003
- Protection circuit using uPC1237 chip
- Relay protection circuit a
- High voltage automatic protection circuit
- Thyristor silicon stack protection circuit a
- Thyristor resistance-capacitance protection circuit b
- Motor overcurrent protection circuit
- AC negative feedback analysis of OCL power amplifier
- OCL power amplifier composed of LM2876
- The simplest structure OCL power amplifier
- Typical OCL power amplifier circuit
