Application circuit of TDA7294
Source: InternetPublisher:张小哥 Keywords: Application circuit TDA7294 BSP output power Updated: 2021/06/29
The power amplifier circuit using 294 groups has the characteristics of simple peripheral circuit and easy production. The input impedance of the circuit
is 20kfl, and the input sensitivity is 750rrN. This circuit can be used for either 8fl load or 40, load.
The output power under the two loads is the same.
Figure 2-74 is a 100W power amplifier circuit composed of TDA7294 , using ±40V voltage and an output power of 100W.
The supporting power supply should have sufficient capacity.
- How to use the Arduino tone function to play a melody on a piezo buzzer or speaker
- Practical and high-performance preamplifier circuit
- DIY 50W Gallstone Amplifier
- Using 6P15 to create an ultra-linear push-pull amplifier
- Stereo phono amplifier circuit with bass control composed of LM1877
- Class AB2 Amplifier-McIntosh MC80
- Class A power amplifier circuit with an output power of 18W
- Tube single-ended class A 300B power amplifier circuit
- American Grado RA1 headphone amplifier
- LM4819 high gain audio amplifier circuit
- Analysis of rectifier circuit types and principles
- Ultrasonic blind pathfinder circuit
- Electronic anti-asthma circuit
- Greenhouse temperature control circuit
- Proportional frequency discriminator circuit
- Integrated synchronous detector composed of analog multiplier MC1596
- Simple AGC circuit in transistor radio
- Parallel crystal oscillator
- Second-order active band-stop filter circuit
- color discrimination circuit
