Composite Class A Amplifier
Source: InternetPublisher:ghaytweyhtoo Keywords: amplifier coupling Updated: 2020/03/27
It is a pure Class B output CL type power amplifier circuit. The front-end input part of this circuit does not use
the traditional differential input circuit, but uses a composite analog A analog rescue circuit with a single-ended input and a single-ended output. Its
working principle is shown in Figure 2-39. It is a directly coupled two-stage amplifier circuit, and its amplification capability is even greater than the two-stage
differential amplifier circuit. In the circuit, REI.Rl is the emitter resistor , which can be used as a DC negative feedback resistor to stabilize its working
point, and as an AC negative feedback resistor to increase the input impedance of the circuit. To match the preamp. The resistor RE is used to
achieve current sharing between the two tubes VTi.VT2.
- The easy production of several top-quality tube preamplifiers
- Using TDA2822 to do direct coupler output experiment
- Field effect tube amplifier circuit with beautiful sound
- Practical and high-performance preamplifier circuit
- Production of 6n3 Pushing 6p1 Single-ended Tube Amplifier
- Design and production of class AB headphone amplifier
- Design of a tube amplifier that uses the mains electricity to directly provide screen working power
- Auxiliary audio power amplifier circuit using LM4730/LM4731
- Bridge output audio power amplifier circuit composed of LM1876
- Audio amplifier circuit of the Expo flowerpot speaker
- Op amp driving LEDs
- High-end four-channel mixer
- TDA2030A subwoofer circuit diagram
- High input impedance three op amp differential amplifier circuit diagram
- LTC2057 Differential Thermocouple Amplifier Circuit Diagram
- Parallel power op amp
- Op amp impedance multiplication circuit
- Low drift peak detector
- Infrared remote control transmitter/receiver circuit
- voltage amplifier circuit
