Simple reference voltage generation circuit using shunt regulator
Source: InternetPublisher:D先生 Keywords: Generating circuit reference voltage regulator Updated: 2021/01/05
The circuit in Figure (a) is used for the regulator circuit. The output voltage y oit
is determined by the formula vout = (1+Rl}Rz) × 2.5. In order to output ioVr, set Ri =
3Rz, and set the bias resistor to B and v. It is related to the load current IL. It should be made that RB ≤ (v.
-v. 21)/ILo. Once the load current of the shunt adjustment circuit is reduced, in order to keep the clamp-
out voltage unchanged, D absorbs the current from Ic meters. TL.431 output impedance When it is several iokHz-
or above, the CL capacitance should be increased to more than 1UF as needed.
Figure (6) is a very simple current conversion circuit. The open-loop gain of TL431
is about sOdB, and the conversion current stability is very good. In order to make current sense electricity.
Resistor 5 produces a voltage of 2. sv, and the base of the transistor must be controlled.
- How about the boost converter TPS61299?
- A very convenient small power supply circuit to share
- Introduction and principle analysis of switching regulated power supply
- Brief Analysis of the Working Principle of AC Voltage Stabilizer Circuit
- INA155/INA156 is used to form a single-supply high-side current monitor for detecting load current
- Low cost and high performance LED constant current power supply
- Integrated regulated power supply with continuously adjustable output voltage
- USB power socket using the car battery
- Self-made high-stability, high-current, DC adjustable voltage-stabilized power supply using operational amplifier
- MAX1811 Lithium Battery Charger Production
- Power circuit a composed of intelligent thyristor modules
- Dual adjustable power circuit
- Industrial product promotion and shopping guide DC power supply circuit
- Reference voltage divider circuit in AD converter
- Power circuit with smoothing filter capacitor
- 500A-6V single-phase thyristor voltage regulating electroplating power supply circuit
- Simple reference voltage generation circuit using shunt regulator
- Industrial four-way programmable controller power circuit
- Sawtooth wave generating circuit
- Positive and negative 10V reference voltage circuit
