High dynamic, low distortion all-crystal triode three-stage differential power amplifier
Source: InternetPublisher:国民男神经 Keywords: Low distortion transistor power amplifier BSP Updated: 2021/05/12
This circuit uses all transistors in order to overcome the shortcomings of the above two circuits. Three-stage
differential amplification is used to reduce the distortion of the power amplifier. We already know that the relationship between the output and input of the closed-loop amplifier circuit is:
i1-
KKoFF1 Stool (1-RoF J)
In the formula, Ux and Ut are the output and input voltages respectively. RA and RB are shown in Figure 4-¨. The negative feedback resistor, F is the voltage feedback
coefficient, and Ko is the open-loop amplification factor.
It can be seen from the formula : When the open-loop amplification factor K. is larger, the l/KoF term is smaller, and the ratio of Ux to U$r U c/U,.r term is close to
the R^/RB term, which means the distortion is smaller. Therefore, When the amplification factor of each stage is the same, the distortion rate of a three-stage difference amplifier is much smaller than that of a power amplifier
with only
one or two stages .
In order to eliminate the transient distortion under deep feedback, this circuit uses In order to form a low-pass filter network formed in the dotted box in the figure
and connect a locl1 resistor between the input terminal and the circuit ground (ov), the off-state distortion is effectively suppressed.
When the circuit outputs low, the distortion The frequency is less than 0.ooz%, the intermodulation distortion is less than 0.003%, and the frequency response is 10Hz~ 68kHz.
- Convenient and fast power line break detection circuit
- Digital electronic thermometer using semiconductor diode as temperature sensor
- System display circuit of electric bicycle speed and odometer composed of CD4076 and 74LS138
- Circuit Fault Tracker
- 4-range digital voltmeter circuit using ADD3701
- Homemade LED digital display photovoltaic meter
- 5 tone detector circuit diagram
- Digitally controlled operational amplifier gain circuit
- High Performance Digitally Controlled Amplifier-Gain Divider
- voltage amplifier circuit
- Excellent performance household inverter power supply circuit
- Smoking Cessation Circuit
- Inpatient pager circuit
- High-efficiency speaker circuit for rural stage
- Poultry warming temperature control circuit
- Integrated synchronous detector composed of analog multiplier MC1596
- collector amplitude modulation circuit
- ring amplitude modulation circuit
- Crabo oscillator circuit
- Digital stopwatch display circuit
