Super fool high power amplifier module 02
Source: InternetPublisher:方世玉223 Keywords: High power power amplifier OCL wiring diagram Updated: 2020/03/16
Using a D series fool amplifier integrated block. A single-channel OTL or OCL audio power amplifier can be easily organized
. Figure 3-12 is a typical application wiring diagram of single-power channel OTL output . Figure 3-13 is
a typical application wiring diagram of positive and negative power supply mono OCL and output . If you need to connect a two-channel power amplifier circuit, you need to use two fool-proof power amplifier modules. Figure 3-14 is a typical application wiring diagram
of two-channel OCL-output using positive and negative power supplies.
- Balcony intelligent invisible anti-theft net
- DIY Metal Detector
- Detection of Bidirectional Trigger Diode
- Temperature Range Monitoring System
- Simple and practical motor short circuit tester
- Simple infrared detector
- Fire detector made with photodiode
- Digital strain gauge circuit using MAX1492/MAX1494
- 4-range digital voltmeter circuit using ADD3701
- Use LM3915 to make a practical audio power meter
- 280W power amplifier power circuit diagram
- 80Wx2 high-fidelity power amplifier
- Power amplifier composed of STK4191
- Fully symmetrical complementary CL amplifier
- Using Darlington amplifier
- Production of high-quality active two-way constant current power amplifier 03
- Application of LM3886 in home theater 01
- QSC1300 power amplifier principle and maintenance
- High-fidelity power amplifier quasi-complementary symmetry (OCL) circuit
- OCL quasi-complementary power amplifier circuit diagram
