Application of TL494 in DC motor speed control
Source: InternetPublisher:拳制龙 Keywords: DC motor TL494 error amplifier Updated: 2021/10/25
When applied in a brush or brushless DC motor
speed control system (see Figure 10
2), one of the error amplifiers is used to input the speed given voltage signal from pin 2, and
the speed feedback voltage signal is input from pin 1. This amplifier is used as a speed regulator. Use,
introduce resistance and capacitance correction between pins 2-3 . The other error amplifier is used as a current limit protection comparator.
The motor current detection signal is introduced from pin 16, and the specified current limit value signal is input from pin 15. This signal can
be obtained from the internal reference voltage source of pin 14 through a resistor divider to start the motor. , or overload
or fault, the overcurrent is limited within a safe range to protect the motor and power switch
tube. In the chip, the PWM signal is obtained by the speed regulator output control. This signal
is used to control the external power stage circuit to maintain the motor speed at a constant value.
- The meaning and importance of circuit protection, common types of circuit protection
- Controlling LEDs with Multithreading via Dual-Core Programming on Raspberry Pi using MicroPython
- How to Make a Hot Tub Smart and Remotely Operated with a Raspberry Pi
- What are the challenges in designing a permanent magnet linear generator?
- How to set up a cheap beam break sensor control distance scene using a reflector
- Squirrel cage asynchronous motor reverse braking control circuit
- Light-controlled circuit design and analysis
- Temperature control circuit design and analysis
- Design and analysis of a four-bit remote control component capable of remote reset
- Do-it-yourself trial production of phase failure protection device
- Agricultural spraying and insecticide control circuit
- fire smoke control circuit
- Paper tension control circuit
- Chandelier control circuit
- Schematic diagram of motor PLC control circuit
- Digital current loop control circuit
- Typical operation display circuit
- Taifu DK2-25 rice cooker temperature detection control circuit
- Forward and reverse control circuit of micro DC motor a
- Micro DC motor steady speed control circuit b
