Serial-to-parallel conversion circuit
Source: InternetPublisher:刘德华河北分华 Keywords: Conversion circuit hardware circuit axis angle AD Updated: 2021/09/23
Serial-to-parallel conversion of absolute axis angle data: There are many methods to convert AD 2S90 serial axis angle data
into parallel data. Timing digital pulse signals can be generated by microprocessors
or hardware circuits . Figure 8 25 shows an example using the hardware circuit . Figure 8 26
is a complete circuit diagram. We use two 74HC595 as shift registers,
a 74LS169 counter/divider, a 74121 monostable and a delay
circuit. Select the correct input clock pulse frequency (SCJ.K) to generate the load pulse
(JO AD PULSE) and chip select pulse (cs).
- How to choose the right level of integration to meet motor design requirements?
- Controlling LEDs with Node-RED in Raspberry Pi
- Build a glove-controlled robotic arm
- How to Build a Gesture-Controlled Elevator Prototype Using Arduino Nano
- Star-delta step-down starting control circuit for squirrel cage asynchronous motor
- Using P110C to control 6 DC motors simultaneously
- Design and production of wireless multi-location control switch circuit
- Audio interface protection circuit
- Design and production of no-load automatic power-off device for household power supply
- Delay switch made with LM431
- Differential amplifier emitter negative feedback gain control circuit
- AD524J type thermocouple cold junction compensation temperature measurement circuit
- LT3783 boost configuration driver LED circuit
- AD590 single point temperature control circuit
- Changfeng KAB-11, KAD-12, KAD-18 wall ventilator circuit diagram
- The sensor and AD694 form a 4 to 20mA transmitter circuit
- AD22050 amplifier circuit
- Using AD586 to generate - 5.000V voltage circuit diagram
- Highly regulated power supply circuit diagram using reference regulator AD580
