AN8290NS CD player spindle driver-Typical application circuit
Source: InternetPublisher:拿铁三分糖 Keywords: Application circuit spindle driver Updated: 2020/12/25
Working Principle and Application Circuit The chip is a 24-pin flat package and is usually
powered by 6 V or +12v. This application example is powered by +1ZV. Its principle block diagram is shown in Figure 3-38
. The application circuit diagram is shown in Figure 3 39.
(¨Hall rotor position sensor: For three-phase full-wave commutation mode,
three Hall elements are usually required. This chip allows the use of only two Hall elements, but their
output must be approximately a sinusoidal transition. Figure In 3-39, pins 13 and 14 are left vacant
, and two Hall elements Hl and H2 are used. The Hall voltage is VH,, y.:,
the voltage y equivalent to the third Hall element can be generated internally... The principle is based on the following operation.
Therefore, the motor magnetic field is required to be an approximate sine wave and a linear output Hall element is used.
This chip is not suitable for motors whose air gap magnetic field is a trapezoidal wave distribution.
- Current output characteristics of brushed motor driver chips. How to increase the peak drive current?
- Use your smartphone to turn on/off the power in your home
- An automated model railroad layout project using a microcontroller
- DC motor drive circuit composed of L293D
- Motor automatic cycle control circuit
- Design and analysis of touch delay switch circuit composed of CD4011 and CD4001
- Design and analysis of voice control circuit
- An experimental model of an infrared radio alarm
- Infrared blocking alarm device
- Precious home appliance anti-theft alarm
- Platinum thermal resistance signal conditioner internal circuit block diagram and typical application circuit
- Basic application circuit of thermistor c
- Basic application circuit of thermistor a
- Electronic stable speed motor application circuit
- PSZ740 application circuit
- AP500 and its application circuit (e)
- TMOS application circuit
- SHM1100 application circuit
- STKxx series application circuita
- Application circuit of TDA2040(A)-dual power supply BTL operation
