Basic application circuit of thermistor a
Source: InternetPublisher:toothache Keywords: thermistor application circuit BSP Updated: 2021/02/10
The basic application circuit of the thermistor is shown in the figure .
Figure (a) shows the most basic temperature measurement circuit. The temperature measurement accuracy of this circuit is not high and can only be used in
situations where accuracy requirements are not high. When RT is a positive temperature coefficient thermistor, when the temperature increases, the output voltage vo increases, and vice versa;
when RT is a negative temperature coefficient thermistor, when the temperature increases, the output voltage vo decreases, and vice versa.
Figure (b) is a thermistor temperature difference measurement circuit using an operational amplifier, and the temperature measurement accuracy is improved. This
circuit can detect the temperature difference between two points. When the temperature at RTi is lower than the temperature at RT2, that is, RTi <RT2, the potential of
terminal (1) of the operational amplifier is higher than the potential of terminal (+), and the output is low level; In the same way, when the temperature of month L is higher than the temperature
of RT2 , the output is high level.
Figure Il (c) is a temperature measurement circuit using an operational amplifier and a logarithmic diode. The logarithmic diode
compensates for the linearity of the thermistor , and RP can adjust the gain of the amplifier, thereby further improving the output characteristics.
- Symbol/working principle/type/characteristics/application scenarios of depletion-mode MOSFET
- How to read resistor color codes? Resistor color codes illustrated
- What are the classifications of filters?
- RC filter explained in detail
- What are the parts of the fpga design process
- Transfer characteristics of BJT, how to apply Shockley equation?
- How to Build a Simple Temperature Indicator Circuit Using NTC and PTC Thermistors
- Structural diagram and function of sliding resistor
- Make a simple AM radio with digital circuit
- LED lights that “drain” battery power
- Set timing circuit when power is on
- Homemade disinfectant circuit
- Egg warming circuit
- Particle clogging alarm circuit of wheat seeder
- Electrical schematic diagram of DC voltmeter input at non-inverting terminal
- Domestic KD8041 integrated phase locked loop
- Proportional frequency discriminator circuit
- Wien bridge oscillator circuit
- Wireless microphone circuit
- color discrimination circuit
