Basic application circuit of thermistor c
Source: InternetPublisher:难得正经 Keywords: thermistor application circuit BSP Updated: 2020/11/07
The basic application circuit of the thermistor is shown in the figure .
Figure (a) shows the most basic temperature measurement circuit. The temperature measurement accuracy of this circuit is not high and can only be used in
situations where accuracy requirements are not high. When RT is a positive temperature coefficient thermistor, when the temperature increases, the output voltage vo increases, and vice versa;
when RT is a negative temperature coefficient thermistor, when the temperature increases, the output voltage vo decreases, and vice versa.
Figure (b) is a thermistor temperature difference measurement circuit using an operational amplifier, and the temperature measurement accuracy is improved. This
circuit can detect the temperature difference between two points. When the temperature at RTi is lower than the temperature at RT2, that is, RTi <RT2, the potential of
terminal (1) of the operational amplifier is higher than the potential of terminal (+), and the output is low level; In the same way, when the temperature of month L is higher than the temperature
of RT2 , the output is high level.
Figure Il (c) is a temperature measurement circuit using an operational amplifier and a logarithmic diode. The logarithmic diode
compensates for the linearity of the thermistor , and RP can adjust the gain of the amplifier, thereby further improving the output characteristics.
- What is a photocoupler and how to select and use one?
- This article will tell you the hard requirements of operational amplifiers
- The Importance and Ideal Model of Impedance Matching
- What are the main types of resistors? Detailed explanation of the functions and uses of resistors
- How to read resistor color codes? Resistor color codes illustrated
- What are the parts of the fpga design process
- Simple Wired Spy Bug Circuit Built Based on IC741
- Build a musical fountain using Arduino and sound sensor
- What is the difference between high-side and low-side resistive current sensing
- LED Bicycle Lights
- Set timing circuit when power is on
- Homemade disinfectant circuit
- Egg warming circuit
- Particle clogging alarm circuit of wheat seeder
- Electrical schematic diagram of DC voltmeter input at non-inverting terminal
- Domestic KD8041 integrated phase locked loop
- Proportional frequency discriminator circuit
- Wien bridge oscillator circuit
- Wireless microphone circuit
- color discrimination circuit
