High quality stereo HI-FI combo amplifier 04
Source: InternetPublisher:国民男神经 Keywords: amplifier stereo HI-FI BSP Updated: 2020/01/07
(4) The power amplifier
TDAis2i made of A1521 is a famous product of Philips, with a rated output power of 15w×2. Although the output power is not very large, it is enough for
family listening to music. In order to improve the power usage, before TDA1521 Plus a positive and negative phase
amplifier with a gain of about 5 times. TDA1521 performs well, the sound is beautiful, and the music is smoother. The disadvantage is that the positioning sense of the sound and image is slightly worse. 9
TDA15 21 is a two-channel integrated circuit, and the working limit is The voltage is ±20V, and ±16V is often used. When in use, the secondary voltage of the transformer
is double 12V, and the power is about 35W.
- Lightweight and practical multi-core cable detection circuit
- Simple and easy to make zero degree detector
- Simple electric tachometer
- Infrared detector
- Circuit Fault Tracker
- Temperature-frequency conversion circuit composed of CD4046
- 1.5V and 9V battery tester circuit diagram
- Electric vehicle luminous voltmeter with undervoltage alarm
- DT8 type 5A current mutual induction three-phase four-wire active energy meter wiring
- High current, high power amplifier circuit
- electromagnetic field sensor
- Agricultural temperature control circuit
- Crop anti-frost circuit
- Straw returning to field crusher circuit
- Double detuned loop frequency discriminator circuit
- Voltage series negative feedback amplifier circuit
- common emitter amplifier circuit
- Power phase sequence display circuit
- Fault signal trip circuit
- Various signal generator circuits
