Power operational amplifier integrated circuit
Source: InternetPublisher:吃掉星星 Keywords: Operational amplifiers integrated circuits servo systems electric motors Updated: 2020/01/05
When used in servo systems, current drive
connection is often used. As shown in Figure 11-1
, the output current IOUT and the input signal
y. . Directly proportional. The current drive method can
reduce
the phase shift caused by the large inductance of the motor and help stabilize the servo
loop.
- How to use a microcontroller to control a servo motor?
- Servo motor pin diagram/working principle/application
- Using P110C to control 6 DC motors simultaneously
- Starting method of asynchronous motor with external frequency-sensitive resistor
- Design and analysis of wire control circuit
- Design and analysis of the principle of automatic power-off switch during power outage
- A novel and practical power line anti-theft and cutting alarm circuit
- Infrared detection alarm
- Water supply reminder after water outage
- Car audio system anti-theft circuit
- Remote control receiving circuit of Panasonic inverter air conditioner indoor unit control circuit
- Simple timing control circuit
- Digital camera flash control circuit
- PLC chain alarm control circuit used in production process
- PLC transmission line automatic reclosing control circuit
- CPU input and output and memory control circuit
- Relay control circuit a
- Electric heater temperature detection control circuit
- Power supply circuit with multiple outputs (MAX1902)
- A lock-out alarm circuit for phase-locked servo system
