LA5522 application circuit
Source: InternetPublisher:笑流年 Keywords: Application circuit motor output voltage BSP Updated: 2020/08/26
Its working principle is briefly described as follows: When the power supply voltage vcc changes or the mechanical load of the motor
changes, it will cause the motor speed to change. The back electromotive
force E is proportional to the rotational speed. As the marrow changes, the voltage across the motor also changes accordingly .
The voltage v sampled from the two points of the adjustable resistors 1 and 4. These voltage changes are reflected and sent to
the non-inverting input terminal of the error amplifier. It is compared with the reference voltage VREF at the inverting input terminal.
After the error is amplified, the bases of the two transistors are controlled, and the output voltage (pin 3) is adjusted. The output voltage of pin 3
is V. . It has a negative feedback control relationship, and the closed-loop control result tends to maintain a constant speed.
- What is a 4-pin PWM header? How do 4-pin PWM fans work?
- Controlling LEDs with Node-RED in Raspberry Pi
- How to build a simple tachometer using an infrared reflectance sensor
- Controlling LEDs with Multithreading via Dual-Core Programming on Raspberry Pi using MicroPython
- What are the challenges in designing a permanent magnet linear generator?
- Replace the GE LOGIQ a200 ultrasound measurement key with a self-made touch switch
- Simple phase failure protection circuit composed of intermediate relay
- Design and analysis of wire control circuit
- Audio interface protection circuit
- Infrared blocking alarm device
- Electronic thermometer circuit
- Pulse therapy circuit
- Inpatient pager circuit
- Agricultural temperature control circuit
- Peanut and melon seeds roasting machine circuit
- Domestic KD8041 integrated phase locked loop
- Parallel crystal oscillator
- Common emitter-common base wideband amplifier circuit composed of F733 integrated amplifier
- Color display circuit
- Sawtooth wave generator circuit (2)
