Circuits for data communications on weak current lines
Source: InternetPublisher:黄土马家 Keywords: data communications lines BSP Updated: 2021/06/22
Transmitting data over weak current lines
If existing indoor wire lines are to be used for network communication, power line carriers are generally used to transmit data on strong power lines. Now I have come up with a simpler, cheaper and more reliable way, which only requires a few discrete devices and two ICs to communicate through weak current circuits (such as telephone lines). To hell with power cats.
The transmission rate of this circuit can reach at least 32kbit/s, and if the carrier wave is higher, the speed can be even faster. For the sake of simplicity, the keypad switches we use do not have noise reduction function. If needed, it can be achieved with software. U1 is a PIC microcontroller, equipped with several peripheral devices and a PWM module.
It should be noted that this circuit can only be used in low-voltage weak current environments and cannot be connected to high voltage.
- Schematic diagram of car cigarette lighter to USB power port
- How to use a simple circuit to achieve a smooth soft-start for an isolated converter
- Using Lead-acid Battery as Power Source for Walkman
- Lithium battery overcharge, over discharge, short circuit protection circuit design
- Brief Analysis of the Working Principle of AC Voltage Stabilizer Circuit
- Principles and precautions of active discharge circuit
- Voltage-current converter constructed with XTR110
- Integrated regulated power supply with continuously adjustable output voltage
- MIC4680 constant current charger
- LM317T voltage regulation adjustable circuit diagram explanation
- Voice controlled flash LED light circuit diagram
- Inpatient pager circuit
- Peanut and melon seeds roasting machine circuit
- Chicken supplementary light to increase egg production rate circuit
- Fish farming thermostatic control circuit
- Biogas concentration detection line
- Proportional frequency discriminator circuit
- Multi-frequency resonant high-frequency power amplifier circuit for transmitter stage
- Second-order active band-stop filter circuit
- Various signal generator circuits
