Five-way flashing light string circuit (1)
Source: InternetPublisher:三月小雨 Keywords: Flashing light BSP ground Updated: 2020/01/07
It is a five-way flashing light controller made of M]DOOI and five flashing light integrated circuits produced by Shenzhen Tianlang Semiconductor Co., Ltd. M1500P is made of [1M()ST Zhi. DIP 14 standard packaging,
soft seal packaging can also be customized according to customer requirements. It uses a power supply with a standard voltage of 3V, I,1 -] and an output terminal that can
directly drive the light-emitting diode to flash. There are two flashing modes to choose from: random and continuous.
In the circle, 220Y AC power
is stepped down by C , Vn rectification and vS
voltage stabilization output a self-current voltage of about 3V for
the 'VI1500P. Pins ⑨~⑩,
that is, terminals 1,1~L5, are respectively connected to
pin ① of the SSRI-SSR5 Yinzhi relay
(i.e., the negative terminal of the built-in light-emitting tube )
R, is the current-following
resistance of the built-in light-emitting tube, so when it is powered on, the five solid
-state relays will turn on and
off one after another, and the light strings El to F5 will
start shine. (), l of the integrated block The /OFF terminal, that is, the ⑦ pin is directly connected to the ground , so the chip starts to work after the circuit
is powered on
. s is the mode selection switch. When Sm is closed, the SEQ terminal is connected to the ground , and the flashing is a continuous horse racing pattern; when S
is opened, the SFQ terminal is suspended. When one hundred groups of light strings flash randomly. R. It is an external oscillation resistor of the integrated block
. Changing its resistance can fine-tune the flashing frequency.
C. It is required to use CBB-400V type polypropylene capacitors; SSR1 ~ SSR5 use TAC081 type IC type
solid state relay, its maximum load current is A. See A for other component parameters, no special requirements.
- Example of LED AC drive circuit
- LED acceleration and deceleration motion display composed of CD4017
- Musical doorbell without buttons
- Infrared remote control device circuit
- Transistor storage time test circuit
- Simple electronic doorbell circuit
- Lighting audio control circuit
- One of the circuits that control one light in multiple placesb
- Electronic rapid starter for fluorescent lamps
- Fluorescent lamp dimming circuit composed of thyristors
- Analysis of rectifier circuit types and principles
- Crop anti-frost circuit
- Rural fish farming control circuit
- DC ammeter
- Varactor Diode Frequency Modulator
- Simple AGC circuit in transistor radio
- Series crystal oscillator
- Inductive feedback oscillator circuit
- Voltage controlled power supply second-order high-pass filter circuit
- color discrimination circuit
