Use HFC3018 to make a six-way lantern controller
Source: InternetPublisher:消失的歌 Keywords: Lantern controller solid state relay lantern Updated: 2021/04/19
This circuit uses the five idle light signals output by HFC3018 to drive the solid-state relays SSRI~SSR5 to turn on
and off in sequence, so that the colored lights HI~H5 can light up and turn off in turn. The analog sound signal output by the integrated block drives the solid state relay
SSR6, so that the 6th group of colored light chain H6 can flash with the analog sound stored in the integrated block. Press the button switch SB once to
obtain a flashing mode. HFC3018 stores eight kinds of analog sounds, so it can produce eight different flashing effects. If switch
SB is short-circuited, Hl~H5 will flash cyclically, and H6 will flash cyclically according to eight analog sound rhythms. Increasing or decreasing the resistor R value can change
the speed of the flashing rhythm.
- LED acceleration and deceleration motion display composed of CD4017
- Working Principle of CCFL and Analysis of Electronic Driving Circuit
- DCD-1240 multifunctional rechargeable lighting
- Solar battery and charging circuit
- Use NE555 to make a touch self-extinguishing table lamp
- Gas flameout alarm circuit
- Infrared remote control dimmer light circuit
- Frost alarm circuit
- Mains undervoltage and overvoltage alarm circuit 2
- 6-digit cathode fluorescent triode display circuit
- Contactless switch conversion circuit a
- Bidirectional thyristor motor drive circuit a
- Solid state relay circuit one c
- Eight-function multi-pattern lantern chain circuit using SE9201
- Multiple sets of light-emitting diode lantern chain circuits with different flashing frequencies a
- Solid state relay controlled forward and reverse starting circuit
- SH-803R holiday lights ASIC
- SE9518 Holiday Lights ASIC
- Simple solid state relay circuit
- solid state relay circuit
