Special voltage doubler rectifier electronic ballast circuit diagram
Source: InternetPublisher:难得正经 Keywords: Battery power supply rectifier electronic ballast Updated: 2021/06/22
This kind of electronic ballast is rare and very popular in the late 1990s because of its low cost!
Its main features are:
1. It has good low-temperature and low-voltage starting performance and can work reliably at ambient temperatures between -20°C and -50°C. When the power supply voltage is 150°/FONT>160V, it can start to ignite the fluorescent lamp in one go.
2. Significant power saving. Compared with traditional magnetic ballasts, under the same illumination, it can save 20% to 25% of power.
3. The impedance of this ballast is capacitive and has a compensation effect on the power grid. The power factor is >0.9.
4. Bad tubes can be restored to sight. The old lamp tube can still be used if one side of its filament is burned out or one of the tubes is blackened.
5. After removing the starter, the original four-wire output is changed to a two-wire output, so it is easy to install and maintain. It is very suitable for high-altitude and embedded places where maintenance is inconvenient.
6. It lights up as soon as it is turned on, no flicker, no noise, no jitter, soft light, and protects eyesight.
7. Wide application range, applicable to all kinds of fluorescent tubes.
C1 to C4 and VDl to VD4 in the circuit mainly play the role of voltage doubler rectification. The capacitance should not be too large, which will easily overheat the output power line; if the capacity is too small, the brightness of the fluorescent lamp will not be enough. Therefore, do not change the capacitance of C1 and C4 at will. Resistors R 1 and R2 provide discharge current loops for capacitors C1, C2 and C3, C4 respectively.
- The basic principles of power supply design. What are the key components of a power supply?
- Step-down power supply for driving relays
- Switching power supply circuit composition and function introduction of each part
- Parallel DC regulated power supply circuit diagram
- Using CW34603 to form a circuit to change the polarity of the output power supply
- Voltage-current converter constructed with XTR110
- LM317 regulated power supply
- USB power socket using the car battery
- Design of electric vehicle charger
- LM317T voltage regulation adjustable circuit diagram explanation
- Metal halide lamp electronic ballast constant power control circuit diagram
- Fluorescent lamp electronic ballast circuit 15
- Fluorescent lamp electronic ballast circuit 12
- EW-8W electronic ballast circuit diagram
- Simplified electronic ballast circuit diagram
- Electronic ballast circuit diagram using thyristor
- High pressure sodium lamp electronic ballast circuit diagram using IR2155
- Overcurrent and overvoltage protection circuit diagram of electronic ballast
- Low cost high power factor electronic ballast circuit diagram
- Electronic ballast circuit 3
