Sequential power-on control circuit
Source: InternetPublisher:已注销 Keywords: Control circuit BSP binary counter electrical equipment Updated: 2020/11/04
Circuit working principle: The power supply part of this circuit consists of power transformer, bridge
rectifier and ripple bypass capacitor. After the 50 Hz, 220 V AC power
is stepped down, rectified and filtered by transformer T, a pulsating DC voltage is output for use by the control circuit
The CD4017 (lC) in the picture is a 5-level Johnson decimal counter chip.
It has a total of 10 output terminals, of which only 4 are used in this article. The flashing LED clocks the decade
counter. After closing S and turning on the circuit, all four
output terminals of the IC Q. , Q3, Qs and Q7 become high one by one at the clock interval of Is, causing the thyristors
vS, ~ VS4 to conduct in sequence and drive the corresponding relay K. One K4. Xs, ~ XS4 are
4 power sockets on the power distribution board, respectively connected to 4 electrical devices . When S is turned
on, since the four sockets must obtain power through their respective relays, the four electrical devices are turned on one by one at the clock interval of Is.
- DIY a practical audio-visual doorbell
- Ways to deliver more than 100A to ADAS processors
- Secret code lock circuit
- Differential voltage or differential current alarm
- Thermocouple Temperature Transmitter
- One of the cooling fan automatic control circuits
- G-6805 therapeutic instrument circuit
- Light controlled electronic bird circuit
- Human body approaching safety protection warning circuit
- One use and one standby constant pressure water supply frequency conversion speed control circuit b
- Motor forward and reverse control wiring diagram (2)
- Chicken supplementary light to increase egg production rate circuit
- Agricultural spraying and insecticide control circuit
- Farmland irrigation automatic control circuit a
- Varactor Diode Frequency Modulator
- Simple AGC circuit in transistor radio
- Schiller oscillator circuit
- Voltage controlled power supply second-order high-pass filter circuit
- color discrimination circuit
- Sine wave signal generator circuit
