LC189 audio voltage controlled lantern control application specific integrated circuit
Source: InternetPublisher:smallembedded Keywords: Audio ASIC lantern control BSP Updated: 2021/02/09
The typical application circuit of LC189 integrated circuit is shown in Figure 2-128. The additional audio
control signal is coupled into
pin 8 of LC189 via C1 . Rl and C2 are external oscillating resistor-capacitor components of the integrated block. Row output terminals A~D and column output terminals A~M
are connected into a 4x4 dot matrix, and LEDl---16 are connected between row lines and column lines respectively. It can be seen from the waveform diagram in Figure 2-127: In the first state,
the luminescent tube on column i lights up; in the second state. The luminous tube on column f lights up; in the 3rd state, the luminous tube on column z
lights up ; in the 4th state, the luminous tube on the ore column lights up; in the 5th state, the luminous tube on row A lights up; in the 6th state In the state,
the luminous tubes on rows A and B are lit; in the 7th state, the luminous tubes on row ABC are lit; in the 8th state, all the light-emitting diodes
are lit, completing a cycle. Repeatedly, wonderful and endless visual effects are formed. The resistors R2~R9 are
the current limiting resistors of the light-emitting diodes. Changing their resistance values can change the brightness of the light-emitting diodes.
This circuit can also expand the number of luminous tubes from
16 to 28. Figure 2-129 provides a 4x7
dot matrix expansion connection method, so that the decorative effect is more
intense.
- IRS2530D electronic ballast circuit diagram
- LED Signage with RS232 Port Operation Guide
- LED Flasher circuit using 2 transistors for LED switching
- Laser detection and indicating device system circuit design
- Electronic massage and acupuncture device circuit
- Infrared remote control device circuit
- Telephone theft automatic notification device circuit diagram
- Shock resistant soft start constant current LED lighting circuit
- Mains undervoltage and overvoltage alarm circuit 2
- Reverse polarity drive circuit
- Analysis of rectifier circuit types and principles
- Bone hyperplasia treatment circuit
- soil content measurement circuit
- Farmland drainage automatic control circuit
- Electrical schematic diagram of DC voltmeter input at non-inverting terminal
- Integrated synchronous detector composed of analog multiplier MC1596
- Schiller oscillator circuit
- common emitter amplifier circuit
- Voltage-controlled voltage source second-order band-pass filter circuit
- color discrimination circuit
