Eight-way answering machine circuit
Source: InternetPublisher:偷熊计划 Keywords: Answering device circuit eight-way answering device coding switch Updated: 2020/04/21
Circuit working principle: It consists of IC, a coding switch and a controller.
The coding switch is composed of input terminals A, B, C, D in the IC, diodes and buttons.
To verify whether the encoding switch is correct, just press and hold any button so that it has a positive
level input and see if the digital tube can display the corresponding number. The four
coding lines A, B, C, and D are 1, 2, 4, and 8 respectively. 3 is
obtained by inputting a positive level from l and 2 at the same time, 5 is obtained by 1+4, and 6 is obtained by 2+ 4 is obtained, and 7 is obtained from 1+2 +4
- LJ2 series transistor proximity switch principle circuit diagram
- Telephone line protection alarm circuit
- One control two constant pressure water supply frequency conversion speed control circuit b
- One control three constant pressure water supply frequency conversion speed control circuit a
- Motorcycle anti-theft alarm circuit-a
- Thermocouple Temperature Transmitter
- Nine-digit key code lock circuit
- Teana A33-EL anti-theft alarm system circuit diagram and schematic diagram 7
- Commonly used oil pump motor control circuits for presses
- Circuit diagram of Shenlong-Fukang DC7140 car diagram reading method example
- Contact switch or proximity sensor circuit
- Diode Balanced Mixer Circuit
- Complementary voltage switching class D power amplifier circuit
- Power phase failure display circuit
- Light touch alarm circuit
- Mechanical electric shock switch value conversion circuit b
- TN-S power supply mode circuit
- Connection circuit of thumbwheel switch ICM7217
- How multi-resonators worka
- Field effect tube time relay circuit 2
