Simple charger circuit that stops when fully charged
Source: InternetPublisher:兰博 Keywords: Charger circuit charger transistor Updated: 2020/08/17
Circuit working principle: When the 12 V battery is fully charged, its terminal voltage rises to
13.5 V. At this time, the transistor VT is turned on, the relay is closed, and K-1 is disconnected, thereby cutting
off the charger power and the charger stops working.
- How to use BME680 to design a smart home control center
- S-Video/PAL Video Converter
- Ultrasonic atomization principle diagram
- Share a home telephone recorder circuit diagram
- DC detection automatic watering controller circuit
- Electronic disinfection cabinet circuit
- Color TV adds AV output socket
- small hearing aid
- Amplifier DIR1703+PCM1738 DAC PCB circuit diagram
- Water and electricity saving faucet circuit 2
- Transistor circuit diagram explanation
- 3 and 1/2 digit digital thermometer using triode as degree sensor
- Composite complementary symmetrical push-pull output stage circuit
- Single supply complementary symmetrical circuit
- Simple second pulse source circuit 2
- Transistor common emitter amplifier circuit b
- Precision regulated power supply circuit for UJ-1 type potentiometer
- One of the water full alarm circuits
- Alarm and protection circuit using operational amplifier
- Flash signal light circuit 7
