Practical AM-4 module circuit schematic designed using TGS4160 sensor
Source: InternetPublisher:闪电杰克 Keywords: Sensor design module circuit circuit schematic diagram Updated: 2021/02/22
By using the TGS4160 sensor and amplifying it with an op amp with high input impedance and low bias current, and then doing some simple calculations, the signal can be measured in the range of CO2 concentration of 300 to 5000 ppm. The signal range is from 0 to several hundred ppm. The millivolt voltage signal can be used for high-precision A/D sampling. If the AM-4 CO2 sensor module provided by Figaro is used, it can be directly applied to automatic ventilation systems or CO2 gas monitoring. This module has an internal A/D converter, and the data has been sampled and processed. The voltage signal it outputs has a linear relationship with the CO2 concentration value. The output voltage signal is 0~3.0V, which is equivalent to a CO2 concentration of 0~3000ppm. In addition, this module also provides relay transfer control signals. When the CO2 concentration is higher than the set value, the output transfer control signal is high level 5V, which can make the red LED light up; otherwise, it will transfer the control signal to low level 0V to make the LED light up. However, the setting value of this module is step-by-step rather than continuously adjustable. It is divided into four levels (can be realized through jumpers on the circuit board). Table 1 and Table 2 respectively provide the concentration value of the threshold switch signal and the jumper connection method. The practical circuit schematic diagram of the AM-4 module is shown in Figure 1.
![Practical AM-4 module circuit schematic designed using TGS4160 sensor](http://www.eeworld.com.cn/circuit/upload/7f07ea5bf9c0758730a43847e5990f37/5c399201dce99d91c13a4b555261c79b.jpg)
ck="window.open(this.src)" alt="Click to see larger image" />
- How to identify common mode interference? Methods to eliminate common mode interference
- Analysis of the basic principle of measuring resistance by bridge method
- What are the classifications of filters?
- Transfer characteristics of BJT, how to apply Shockley equation?
- Share an interesting LED decoration project
- Important things to know about PCB routing and how to design the right routing for your PCB
- What is a Demultiplexer
- Experiment and production of NE555 time base integrated circuit
- Circuit diagram of an example of differential and integral circuits
- Homemade air conditioner outdoor unit shutdown indicator
- LED energy-saving lamp circuit principle circuit diagram
- Three-phase induction motor circuit schematic using starting compensator
- Correct application circuit schematic diagram of UAA4002 when there is no negative power supply
- Anti-oversaturation function deletion circuit schematic with desaturation protection
- DC voltage converter circuit schematic diagram
- Internal circuit schematic diagram of F001
- Smartphone charger module circuit diagram
- Homemade three-terminal voltage stabilizing module circuit diagram
- 3 to 30V universal power module circuit
- XTR101 circuit schematic diagram
