LED backlight drive circuit diagram
Source: InternetPublisher:桂花蒸 Keywords: LED backlight backlight driver driver circuit diagram Updated: 2021/06/19
In this circuit, Vd is the TFT-LCD backlight operating DC voltage, and its size is designed according to the specifications provided by the LCD manufacturer. Transistors VT1 and VT2 form a constant current source circuit. VT1 and VT2 work in the amplification state. When VT2 works, adjust the base resistor R22 to make the emitter current of VT2 reach the rated value. Because the internal resistance will become smaller after the LED is turned on, the current will gradually increase. The purpose of increasing VT1 is to shunt the base current of VT2. By adjusting the feedback resistor R20, the current flowing through the LED can be controlled and the current can be stabilized through VT1.
- Fire safety evacuation emergency signs
- Measurement and analysis of automatic emergency lighting circuit
- Laser detection and indicating device system circuit design
- Simple electronic doorbell circuit
- One of the bead-type emergency light circuits
- Gas flameout alarm circuit
- Lighting audio control circuit
- Desk lamp dimming soft switch circuit
- Automotive LED driver circuit diagram using LT3486
- Seven-way flashing light string circuit
- Thyristor drive circuit diagram composed of TDH98072
- 3W high power LED drive circuit diagram
- LED backlight driver module design circuit
- Detailed explanation of the design of boosted high-brightness LED backlight drive circuit based on HV9911
- LED backlight drive circuit
- 50W white LED headlight driver circuit diagram based on LT3755
- Gate low voltage protection drive circuit diagram
- 400HZ drive circuit diagram
- 44V AC drive circuit diagram
