Basic connection circuit of signal and power supply of INA326/327
Source: InternetPublisher:黄土马家 Keywords: power supply Updated: 2021/10/31
The figure shows the basic connection circuit of the signal and power supply of INA 326/327 . Choose the highest precision 0.1μF capacitor as power filter and place it as close to the chip power pin as possible. Ro and Co are output filters, which can filter out the noise output by the circuit; at the same time, they can be used as input filters for the next-level circuit , such as input filtering for analog-to-digital converters. The output voltage is based on the ground terminal of R2//C2. Co and C2 combine to form a -3dB bipolar frequency response at 1kHz, with each pole at 1.5kHz. Unlike other instrumentation amplifiers, INA326/327 uses unique internal technology to achieve excellent common mode rejection ratio, so there is contact resistance during the connection process (such as socket contact resistance), which will not reduce the common mode rejection ratio. In order to achieve better high-frequency CMR, a small capacitor can be added between pins 1 and 8.
- Voltage divider circuit calculation formula, where to find the voltage divider circuit?
- How do pull-up resistors work? How do I choose a pull-up resistor value?
- What does a rectifier do? What is the process of rectification?
- In-depth analysis of energy losses in oscillation frequencies
- Ideal characteristics of operational amplifiers/pin configurations/gain types/primary applications
- How does sand become chips?
- Causes and solutions for noise in digital Class D amplifiers
- Build a musical fountain using Arduino and sound sensor
- Introduction of TDA4863J/4863AJ TV field scanning IC
- Using an Op Amp to Drive a Simple and Practical Power Amplifier
- How should the power supply be decoupled?
- Redefine camera power modules with scalable PMIC simplified design
- Summary of key points of switching power supply PCB layout, worth collecting!
- Principle and circuit diagram of battery internal resistance tester
- Will you use the ultra-wide ultra-high voltage input power module PV200-29Bxx?
- Causes of inductor whistling in DC/DC circuits and related solutions
- EMC design component selection and circuit design are critical
- Application circuit diagram of IGBT in CO2 gas shielded welding power source
- AD594-595 functional diagram
- Power indicator circuit
