Triangular wave carrier generator circuit diagram
Source: InternetPublisher:JFET Keywords: triangle wave circuit diagram carrier wave Updated: 2020/03/16
As shown in the figure, the triangle wave circuit consists of two OPs . R62 is the OFFSET adjustment and R27 is the peak adjustment. By selecting different resistors through the switch, triangle waves of different frequencies can be obtained.
ck="window.open(this.src)" alt="Click to see larger image" />
- How are diodes made using semiconductors?
- Analysis of the flow direction of transistor current
- What does a rectifier do? What is the process of rectification?
- What is the relationship between capacitance and impedance in an AC circuit? How do you calculate the impedance of a capacitor?
- How to identify common mode interference? Methods to eliminate common mode interference
- RC filter explained in detail
- Datasheet/Pinout/Technical Specifications of LMC555
- Important things to know about PCB routing and how to design the right routing for your PCB
- Structural diagram and function of sliding resistor
- Experiment and production of NE555 time base integrated circuit
- LM567 decoding alarm circuit diagram
- Small capacitance and long duration timer circuit diagram
- High-precision nanoamp level current generator circuit diagram
- Car power supply voltage monitoring circuit diagram
- Wireless transmitter principle circuit diagram
- Radio receiving circuit diagram of TA31136
- Circuit diagram of wireless ECG monitoring system based on GPRS
- Stable ultra-low frequency triangle wave-square wave oscillation circuit
- Triangular wave-square wave generator circuit diagram
