Low distortion audio limiter circuit diagram
Source: InternetPublisher:睡不醒的小壮 Keywords: low distortion controller circuit circuit diagram audio Updated: 2021/02/03
The level in the audio limitercan be adjusted using the limit level trimpot. If the potentiometer level is exceeded, the output of the limiting detector from half the op amp (acting as a comparator) causes the LED to light up and the photoresistor's resistance rapidly decreases. At the same time the gain of the limiter of the other half of the op amp increases. When the signal falls below the desired limit level, the LED goes out, the resistance of the photoresistor increases, and the gain of the op amp's limiter is reduced to normal levels. The combination of resistors R1 and R2 determines the normal level of gain.
- How to use the Arduino tone function to play a melody on a piezo buzzer or speaker
- TDA2009A power amplifier circuit
- The easy production of several top-quality tube preamplifiers
- The fun of making ISD1820 voice recording box
- Design and production of NE5532+TDA1521 amplifier
- A simple and practical tube amplifier
- Dual power supply audio power amplifier circuit using LM1875
- Class A power amplifier circuit with an output power of 18W
- Typical circuit of LM4809/LM4810 for dual-channel headphone amplifier
- Stereo amplifier circuit with Av=200 (gain) composed of LM1877
- How to learn circuit diagrams?
- Typical super regenerative radio receiver circuit diagram
- Input status indication circuit diagram
- LED level meter driver integrated circuit diagram
- Low distortion oscillator circuit using varactor diodea
- Modulator circuit for test signal generator
- Modulator circuit using 4153 function generator
- Simple pulse width modulator circuit
- DCQ series electric hoist overload limiter circuit
- Pulse position modulator circuit diagram
