Input status indication circuit diagram
Source: InternetPublisher:傻阿乐 Keywords: Circuit diagram digital tube diode Updated: 2021/05/07
This circuit monitors the data input of one bit and displays "H" or "L" on the 7-segment digital tube according to its status. This circuit uses two 7437 inverters and a DL-704 common cathode digital tube. The diode symbol represents a segment of the digital tube (segment A is not needed when displaying H or L). The power connection method of the 7437 inverter is 14 connected to +5V and 7 connected to ground.
- Example of LED AC drive circuit
- Six LED stereo VU display circuit built with IC LM3915
- Blinking LED circuit diagram based on LDR and resistor
- Design and production of rain control and light control timing controller based on P87LPC764
- "OR" logic element configuration circuit
- Lighting lamp voltage stabilizing circuit (2)
- Simple electronic doorbell circuit
- Gas flameout alarm circuit
- Mains undervoltage and overvoltage alarm circuit 2
- Reverse polarity drive circuit
- Acousto-optic digital level detector circuit diagram
- Intrinsically protected safety op amp
- Object presence and displacement detection circuit
- 3 and 1/2 digit digital thermometer using diode as temperature sensor
- Low supply voltage diode temperature measurement circuit
- High frequency signal input switch circuit a
- Mosquito killer lamp circuit
- Internal structure of DTL inverter circuit
- Fast response circuit b when controlled by transistor
- Multiple sets of colorful light chain circuits that flash in cycles (Part 3)
