Low distortion oscillator circuit using varactor diodea
Source: InternetPublisher:拿铁三分糖 Keywords: Varactor diode oscillation circuit low distortion BSP Updated: 2021/11/02
Shown is a low distortion oscillator circuit using varactor diodes . The use of varactor diodes (or double varactor
diodes) in transistor oscillators can achieve electrical tuning and can also be made into voltage-controlled oscillators, usually for low-control oscillators.
Inductors and capacitors connected in parallel can form an LC parallel resonant circuit. In the resonant circuit, the varactor diode is essentially equivalent to a variable
capacitor. The DC control voltage is added to the varactor diode to fine-tune the junction capacitance of the varactor diode. the size of. Therefore, the DC control voltage can also
be said to be a tuning voltage. Changing the control voltage value can change the oscillation frequency of the oscillator.
- The unidirectional conduction current of the diode, the diode and its common uses
- How does sand become chips?
- What is the difference between CPLD and FPGA?
- What is a D flip-flop and how does it work?
- Diode-based clipping circuit
- DIY a decorative lamp
- How to install the accelerometer
- Touch circuit design and analysis
- Purpose and composition of amplifier circuit: low frequency voltage amplifier amplifier circuit
- Circuit diagram of a differential amplifier circuit
- Analysis of rectifier circuit types and principles
- Bone hyperplasia treatment circuit
- Electronic anti-asthma circuit
- soil content measurement circuit
- Electrical schematic diagram of DC voltmeter input at non-inverting terminal
- Frequency modulator composed of NE566
- Integrated synchronous detector composed of analog multiplier MC1596
- ring amplitude modulation circuit
- Second-order active band-stop filter circuit
- Fault signal trip circuit
