Voice bandpass circuit
Source: InternetPublisher:清宁时光 Keywords: WIDTH Updated: 2020/06/14
Used to connect an 8-ohm output communication receiver and an 8-ohm speaker or low- impedance phone to suppress continuous random harmful interference during voice transmission . Passband 355 to 2530Hz, 3dB. L1 and L3 are 4amH rings. L2 is an 88mH ring.
- Voltage divider circuit calculation formula, where to find the voltage divider circuit?
- How do pull-up resistors work? How do I choose a pull-up resistor value?
- What is a pure resistance circuit? What is a pure resistance AC circuit?
- This article will tell you the hard requirements of operational amplifiers
- What is the difference between CPLD and FPGA?
- Working principle/characteristics/application fields/equivalent circuit of unijunction transistor
- TL494 pin functions/configuration/ratings/operating conditions/layout diagram
- How to Build a Simple Temperature Indicator Circuit Using NTC and PTC Thermistors
- What is a Demultiplexer
- Common electrical circuits: frequency-selective (bandpass) amplifier circuit
- LA4555 power amplifier circuit diagram
- LA4510 power amplifier circuit diagram
- LA4185 power amplifier circuit diagram
- HA1384 power amplifier circuit diagram
- AN7161N power amplifier circuit diagram
- AN7116 power amplifier circuit diagram
- 8W audio amplifier integrated circuit
- Small (2~3 meters) neon light electronic transformer circuit diagram
- MAX1870A - Typical Operating Circuit
- LinkSwitch-PL series LED driver circuit diagram
