555 intermittent ozone generator circuit diagram
Source: InternetPublisher:闪电杰克 Keywords: Generator circuit circuit diagram ozone generator Updated: 2021/05/06
The ozone generating circuit is shown in the figure, which includes a low-voltage power supply circuit, an ultra-low frequency pulse oscillation circuit, a high-frequency multivibrator, a high-frequency pulse excitation stage, etc. IC 2 (555) and R1, R2, D1, D2, RP1, C3, etc. form a low-frequency multivibrator, whose oscillation frequency is f=1.44/(R1+R2+RP1)C3.
The oscillation frequency of the parameters shown in the figure is about 0.025Hz, that is, the oscillation period is about 40 seconds. Adjusting RP1 can change the duty cycle of the oscillation pulse. If the duty cycle is set to 1:1, the positive and negative level durations are about 20 seconds each. During the duration of the positive pulse, the subsequent stage IC3 is powered to work; during the low level period, IC3 is forced to reset and does not work, that is, it provides working power to IC3 intermittently. IC3 (555) and R5, R6, C5, etc. form a controllable multivibrator with an oscillation frequency of f=1.44/(R5+2R6)C5.
The parameters shown in the figure work around 30kHz. Since the voltage at pin 4 of the forced reset terminal of IC3 is controlled by the output level of IC2, when the pulse is low level (less than 0.5V), IC3 is forced to reset and does not oscillate. Therefore, by adjusting RP1, the pulse duty cycle of IC2 can be adjusted, thereby changing the pulse oscillation time of IC 3 to adjust the time of ozone generation, thereby achieving the purpose of changing the ozone concentration in the air.
The driving power tube can be TIP42, 3 CD 10B, etc.
- What is a FinFET? What are the advantages and disadvantages of FinFET?
- Voltage divider circuit calculation formula, where to find the voltage divider circuit?
- Which one is better, NPN or PNP transistor?
- The Importance and Ideal Model of Impedance Matching
- What are the parts of the fpga design process
- TL494 pin functions/configuration/ratings/operating conditions/layout diagram
- Important things to know about PCB routing and how to design the right routing for your PCB
- Introduction of TDA4863J/4863AJ TV field scanning IC
- Experimental circuit based on 4040 binary adder counter
- Experiment and production of NE555 time base integrated circuit
- Sawtooth wave generator circuit (1)
- square wave generator circuit
- Adjustable pulse generator circuit
- Triangular wave generator circuit
- Voice controlled music generator circuit
- Programmable function generator circuit with logarithmic changing frequency
- Function generator circuit using 8038
- Pulse signal generator circuit composed of CMP-04
- Phase shift signal generator circuit using VMOS transistors
- Two examples of 60Hz time base signal generator circuit circuit-b
