Circuit diagram of electronic thermostat for liquids
Source: InternetPublisher:赔钱虎 Keywords: Thermostat circuit diagram Updated: 2020/10/31
The thermistor K273 can be used to monitor and regulate the temperature of a fluid , which is always immersed in the liquid. A bridge circuit is composed of a differential amplifier. The principle of selecting the resistance of the bridge arm is that the voltage drop on the thermistor is higher than the voltage drop of the emitter resistor of the differential amplifier until the temperature adjusted by switch S. In this way, the base of transistor T1 is turned on with a positive potential relative to the emitter, T2 is turned off, and the relay is released. Its normally closed contact rl connects the heating element. Once the temperature on the thermal element reaches the set temperature, the differential amplifier is switched and the heating stops.
Main technical data: Working voltage: 220V, 50Hz Adjustable temperature: 25, 60 or 95 degrees Celsius Temperature deviation of the circuit (at 20 to 70 degrees Celsius): 0.5 degrees Celsius Temperature difference between the regulator on and off: 1.5 degrees Celsius.
ck="window.open(this.src)" alt="Click to see larger image" />
- How to use a microcontroller to control a servo motor?
- Design and selection of electric control valve system drive
- The meaning and importance of circuit protection, common types of circuit protection
- Car ice warning circuit sharing
- Controlling LEDs with Multithreading via Dual-Core Programming on Raspberry Pi using MicroPython
- Working principle of one Xipu STR soft starter controlling two motors
- Controlling stepper motors with wireless remote control transceiver and PE-51 board
- Motor control circuit for starting and running without phase loss
- One-way rotation circuit of motor controlled by contactor
- A novel and practical power line anti-theft and cutting alarm circuit
- Egg warming circuit
- Photocell trigger control circuit
- Mobile phone camera flash control circuit
- Infrared voice control circuit
- Table printing machine control circuit
- PLC transmission line automatic reclosing control circuit
- Multi-pole leakage protector circuit b
- Timing and fire power control circuit
- Photoelectric detection output control circuit
- Temperature detection control circuit for vegetable greenhouses
