High voltage EL lamp driver sp44003 circuit diagram
Source: InternetPublisher:王达业 Keywords: circuit diagram driver high voltage Updated: 2020/09/26
SP4403 is a high voltage EL lamp driver . Its input voltage is DC 1.8~6v, and its output is AC high voltage. It is specially used to drive high-voltage EL lamp driving circuits for backlighting such as LCDs and portable digital processors.
Features: SP4403 can provide a power supply voltage of more than 160 P, which is especially suitable for driving cold light lamps. It only needs to connect an external inductor of 470p H to generate high voltage, and an external resistor to adjust the frequency of the oscillator. The current in the shutdown state is less than 110hA. SP4403 includes a DC/ AC converter internally, which can generate an AC output voltage up to about 220Vp-p to drive EL lamps that require high-voltage power supply. SP4403 has 8-pin P SO IC and SOP. 8Two packaging forms.
Application scope: SP4403 can be widely used in PDAs, pagers, mobile phones and other handheld low-power portable products that need to be used in weak light situations and use LCD screens.
Application circuit: The typical application circuit of SP4403 is shown in the figure.
- Working Principle of CCFL and Analysis of Electronic Driving Circuit
- IRS2530D electronic ballast circuit diagram
- Use MC1455PIG to make automatic cycle light-emitting diode circuit
- Musical doorbell without buttons
- Practical sensitive light-controlled switch circuit diagram
- "OR" logic element configuration circuit
- Mains undervoltage and overvoltage protection circuit 2
- Seven-way flashing light string circuit
- Fluorescent lamp dimming circuit composed of thyristors
- Reverse polarity drive circuit
- Car power supply voltage monitoring circuit diagram
- Micro wireless FM microphone circuit diagram
- Wireless transmitter principle circuit diagram
- Fingerprint identification system circuit diagram based on FPGA
- Delayed AGC principle circuit diagram
- Hitachi RAS-5102 inverter air conditioner remote control transmitter circuit diagram
- Electric iron automatic temperature adjustment principle circuit diagram
- Car battery charging circuit diagram
- One-digit display timer circuit diagram
- Four bedrooms and two living rooms circuit diagram
