Series voltage regulator circuit diagram with adjustable output voltage
Source: InternetPublisher:吃掉星星 Keywords: Series voltage regulator circuit circuit diagram output voltage WIDTH Updated: 2020/08/11
The circuit output voltage can be continuously adjusted from zero to maximum. The reference quantity is a constant current circuit powered by an auxiliary power supply. The reference current can be adjusted by a 500 ohm trimmer resistor, and its value should be about 7mA. This current flows through the 2.5k ohm potentiometer and forms a voltage drop from zero to the maximum value of the output voltage, thereby making the output voltage Ua continuously adjustable from zero to the maximum value.
ck="window.open(this.src)" alt="Click to see larger image" />
- A very convenient small power supply circuit to share
- Benefits of Wide Bandgap Technology for Power Converters
- Cleverly use the electronic ballast of waste energy-saving lamps as power supply transformer
- Fabrication of multi-cell lithium battery charging circuit
- What kind of circuit is a voltage regulator circuit?
- MT3608 constitutes a 3.7V to 12V boost circuit diagram
- Use pulse width modulation to get a precise output voltage
- Integrated regulated power supply with continuously adjustable output voltage
- Car power 1.5V-12V six-speed converter
- Converting a lithium battery charging board into a constant voltage and current charger
- Solar water heater water automatic control circuit diagram
- CD4520, CD4511, CD4067 digital display automatic inspection circuit diagram
- Automatic disconnect battery charger circuit diagram
- Magnetic induction transmitter circuit diagram
- Transistor light meter circuit diagram
- 50W white LED headlight driver circuit diagram based on LT3755
- Circuit diagram of using NCP3065/NCP3066 to drive LED
- High energy efficiency, low cost, non-isolated 350mA/12V LED driver
- Variable gain amplifier circuit
- Guitar noise circuit diagram
