TW-42 ultra-short wave radio transmitter high frequency power amplifier circuit part
Source: InternetPublisher:天天都吃好吃的 Keywords: Amplifier ultra shortwave shortwave radio Updated: 2021/01/30
It is a high-frequency power amplifier circuit for ultra-short wave radio transmitter. This circuit uses the high-frequency integrated power discharge
circuit M57704H from Mitsubishi Corporation of Japan.
The radio station uses frequency modulation, the operating frequency is 457-458MHz, and the transmitting power is 5w. As can be seen from the figure, after the input constant amplitude FM signal
is amplified by M57704H, one path is matched and filtered by the microstrip line, and then sent to the multi-section LC network through VT1, and then transmitted
out by the antenna; the other path is detected by VD2 and VD3 . After VT2 and VT3 are DC amplified, they are sent to the VT1 adjustment tube, which is
used as a control voltage from the second pin of M57704H to adjust the collector power supply of the first-stage power amplifier, which can stabilize the output power of the entire integrated power amplifier. The collector power supply of the second and third stage power amplifiers
is fixed at 13.8V.
- How to Build a Simple FM Radio Receiver on a Breadboard
- Methods to reduce mutual coupling between antenna elements
- TA7792 Medium Wave Radio Circuit Diagram
- FMA9901A FM broadcast dedicated antenna
- MAX2820/MAX2821 I/Q 2.5-2.4 GHz Transceivers
- DKl000R OOK 315 MHz Receiver Module
- GPS RF front-end circuit composed of MX2740
- TX4930 FM/FSK 915/868/433 MHz Transmitter
- rfHCS362G/362F ASK/FSK 440~310 MHz KEELOQ Code Hopping Transmitter
- MICRF500 FSK 1000~700 MHz Transceiver
- Dedicated servo stabilized power supply for power amplifier
- BTL power amplifier composed of single power amplifier
- 80Wx2 high-fidelity power amplifier
- DC power amplifier composed of STK4036X1
- The simplest structure OCL power amplifier
- Production of high-quality active two-way constant current power amplifier 02
- Homemade high-quality integrated amplifier 01
- QSC1300 power amplifier principle and maintenance
- 110W fever amplifier driven by uPC1342V
- Simple 50W high-quality power amplifier 02
