Homemade USB interface powered mobile phone battery charger circuit diagram
Source: InternetPublisher:狂妄火龙果 Keywords: Power supply mobile phone battery battery charger USB interface Updated: 2021/02/08
The charging current of this circuit has two levels to choose from: 100mA (when switch SB is open in the picture) and 500mA (when switch S is closed in the picture). When pin 1 of the MAX1811 allowed by the circuit is connected as shown in the figure, the maximum charging voltage is 4.2V; when pin 1 is connected to the negative terminal of the power supply, the maximum charging voltage is 4.1V. Once the maximum charging voltage is reached, the charging current decreases sharply and the maximum charging voltage remains unchanged. In the figure, VD1 is used as the power indicator, and VD2 is used as the charging indicator. The light is on to indicate charging, and the light is off to indicate the end of charging.
- TPS274C65 helps reduce downtime and increase productivity in 24 VDC power distribution plants
- Recommended circuits for different power on times of LM4911
- Use pulse width modulation to get a precise output voltage
- LED Driver ZD1680
- Low cost and high performance LED constant current power supply
- Dual forward converter schematic diagram
- Integrated regulated power supply with continuously adjustable output voltage
- 0.7~24V continuously adjustable current limiting power supply
- Adjustable voltage power socket
- Detailed explanation of mobile phone charger circuit diagram
- Current type anti-tamper circuit
- Single-ended input circuit (5V power supply)
- Wiring e when leakage protector supplies power to single-phase load in TN system
- Wiring c when the leakage protector supplies power to single-phase loads in the TN system
- Incandescent lamp life extension circuit 6
- New alarm circuit for toys
- Several drive circuits for micro DC motors powered by 3V
- Timing AC power supply circuit diagram that supplies power for 0-1 hour
- Homemade USB interface powered mobile phone battery charger circuit diagram
- Single-phase power quantitative power supply circuit
