74HC14 circuit diagram and information
Source: InternetPublisher:toothache Keywords: Integrated power supply 74hc14 six inverting Schmitt trigger Updated: 2021/10/26
The role of 74HC14: Six inverted Schmitt trigger
Truth table: Y=A
Input input output output AYLHHL
![Pin function](http://www.eeworld.com.cn/circuit/upload/0c1126cf9d455c96e5b88239846bf00f/d7f762f47b3f357d8804b26d78f58c49.jpg)
Figure 1 Pin functions
Limit parameters:
Supply Voltage Supply Voltage 7VInput Voltage Input Voltage 7VOperating Free Air Temperature Range Free Air Temperature Range 0℃ to +70℃ Storage Temperature Range Storage Temperature Range -65℃ to +150℃
Recommended Operating ConditionsRecommended Operating Conditions
Symbol Parameter Parameter Minimum Typical Maximum UNIT Unit VCCSupply Voltage Supply voltage 4.7555.25VVT+Positive-Going Input Threshold Voltage Forward input threshold voltage (Note 2) 1.41.61.9VVT-Negative-Going Input Threshold Voltage Negative input threshold voltage (Note 2)0.50.81VHYSInput Hysteresis Input hysteresis (Note 2)0.40.8-VIOHHIGH Level Output CurrentHigh level output current---0.4mAIOLLOW Level Output CurrentLow level output current--8mATAFree Air Operating TemperatureOperating temperature 0-70℃ Note 2: VCC = 5V.
Electrical Characteristics over recommended operating free air temperature range (unless otherwise noted)Symbol Parameter Parameter Conditions Conditions Minimum Typical Maximum UNIT Unit VIInput Clamp Voltage Input clamp voltage VCC = Minimum, II = -18mA---1.5VVOHHIGH Level Output Voltage Output high-level voltage VCC = minimum, IOH = maximum VIL = maximum 2.73.4-VVOLLOW Level Output low-level voltage VCC = minimum, IOL = maximum-0.350.5--Output Voltage Output voltage VIH = minimum---VVCC = Minimum, IOL = 4mA-0.250.4IT+Input Current at Positive-Going Threshold Positive-Going Threshold Input Current VCC = 5V, VI = VT+--0.14-mAIT-Input Current at Negative-Going Threshold Negative-Going Threshold Input Current VCC = 5V, VI = VT---0.18-mAIIInput Current @ MAX Input VoltageInput current@Maximum input voltageVCC = Maximum, VI = 7V--0.1mAIIHHIGH Level Input CurrentInput high-level current VCC = Maximum, VI = 2.7V- -20μAIILLOW Level Input Current input low level current VCC = maximum, VI = 0.4V---0.4mAIOSShort Circuit Output Current short circuit output current VCC = maximum (Note 4)-20--100mAICCHSupply Current with Out puts HIGH high level output Supply current VCC = Maximum -8.616mAICCLSupply Current with Outputs LOW Low level output power supply current VCC = Maximum -1221mANote 3: VCC = 5V, TA = 25℃.Note 4: Not more than one output should be shorted at a time, and the duration should not exceed one second.
Switching Characteristics at VCC = 5V and TA = 25℃
Switching Characteristics at VCC = 5V and TA = 25℃Symbol
Parameter Parameter
RL = 2kΩ UNIT Unit CL = 15pFCL = 50pF Minimum Maximum Minimum Maximum tPLHPropagation Delay Time LOW-to-HIGH Level Output low to high level output transfer delay time 522825nstPHLPropagation Delay Time HIGH-to-LOW Level Output high to low level output transfer Delay time 5221033ns
Application circuit:
![Photoelectric coupler receiving and shaping circuit](http://www.eeworld.com.cn/circuit/upload/0c1126cf9d455c96e5b88239846bf00f/9c442f0f7ebc158545c8be65b10ecc13.jpg)
Figure 2 Photoelectric coupler receiving and shaping circuit
![square wave oscillator](http://www.eeworld.com.cn/circuit/upload/0c1126cf9d455c96e5b88239846bf00f/848ca84ef8412575339714f06c8f9b51.jpg)
Figure 3 Square wave oscillator
- Redundancy principle of power management system, a redundant design strategy in outdoor power BMS
- 220V Remote Load Monitor
- Energy-saving motorcycle rectifier regulator
- Basic circuit description of adjustable voltage regulator LM317
- Op amp power supply decoupling bypass measures
- Boost drive circuit composed of RT8450
- Adjustable regulated power supply with current limiting protection
- USB power socket using the car battery
- Reconstruction of the tube pre-stage by using low voltage difference power supply
- Homemade home inverter circuit diagram
- 3v to 5v circuit diagram
- 4-phase CPU power circuit using HIP6301 and HIP6602 chips
- Timing switch AC power circuit
- Class A power amplifier power circuit
- led drive power circuit
- Household emergency power circuit
- Common power circuits and applications 04
- CTX-C2 dual-band high-resolution color display power circuit
- COMPAQ 420G type SVGA color display power supply circuit
- CASPER TM-5158 VGA color display power supply circuit
