Three-dimensional stereo effector circuit diagram
Source: InternetPublisher:三月小雨 Keywords: circuit diagram stereo Updated: 2021/11/02
Using two speakers to produce a three-dimensional (3D) stereo effect with a strong surround feeling has become a hot spot in the market because of its low price and high quality. This circuit integrated circuit is Yamaha's YSS247. The characteristic of YSS247 is that it can provide high-fidelity center sound and stable stereo positioning; when reproducing sounds moving in the horizontal direction, such as aircraft flying or taking off and landing, the sense of space makes the listener feel like they are actually there. territory. It can provide sound sources from LD, CD , VCD , FM, Walkman, Tape, PC, etc. Especially when living conditions are limited and the distance between the two speakers is not large, the 3D effect it produces is particularly outstanding. But the mono signal does not produce false stereo, but passes through it. In the circuit, W1 and W1' are sound field broadening adjustments; W2 and W2' are treble adjustments; W3 and W3' are bass adjustments; and potentiometers K and K' are mono pass-through selections. The tone control performance is: plus or minus 10dB at bass 100Hz, plus or minus 10dB at 10kHz treble.
ck="window.open(this.src)" alt="Click to see larger image" />
- How to adjust the bass and treble of CXA1005
- 6P3P parallel 20W power amplifier experiment
- Field effect tube amplifier circuit with beautiful sound
- Production of 6n3 Pushing 6p1 Single-ended Tube Amplifier
- Make a pocket amplifier with 8550 and 8050
- Design of a tube amplifier that uses the mains electricity to directly provide screen working power
- 6AS7 tube amplifier
- Tube single-ended class A 300B power amplifier circuit
- Audio amplifier circuit of the Expo flowerpot speaker
- Stereo amplifier circuit with Av=200 (gain) composed of LM1877
- Electronic circuit diagram tips
- Simple level conversion circuit diagram
- Dual timer circuit diagram that works periodically
- 220V welding machine wiring circuit diagram
- Electronic frostbite treatment device circuit diagram
- Bus stop indicator circuit diagram
- Micro wireless FM microphone circuit diagram
- Lithium battery fast charger circuit diagram design
- Delayed AGC principle circuit diagram
- Regeneration receiving circuit diagram
