Bus stop indicator circuit diagram
Source: InternetPublisher:spectrum Keywords: circuit diagram indicator circuit Updated: 2021/03/01
IC 1 (555) and RtCt form a monostable circuit, and the timing time td1=1.1RtCt. When AN is pressed, the timing pulse output by IC1 is added to IC2. IC2 is a preset 4-bit binary reversible reader CD4516; IC3 is a 4-bit latch 4-16 line decoder. Press once for each station. AN, then IC2 and IC3 perform the calculation of adding 1 (or subtracting 1), the output Q1~Q4 of IC2 enters the decoder for decoding, and then the decoding output is fed back by the IC5 delay circuit to control IC 3 .
- How to use MFRC522 to create an RFID card reader security system
- How to build an electric vehicle EV charger
- LJ2 series transistor proximity switch principle circuit diagram
- One control two constant pressure water supply frequency conversion speed control circuit b
- One control three constant pressure water supply frequency conversion speed control circuit a
- Electric massager circuit
- Two-channel SL320 level indication circuit
- JS13 type transistor time relay circuit
- Sensor alarm circuit
- Electronic ventriloquist circuit
- Common double-tube energy-saving lamp circuit schematic diagram
- Introducing the CD4013 washing machine timer circuit diagram
- Simple level conversion circuit diagram
- Mobile phone production of remote home appliance remote control circuit diagram
- 220V welding machine wiring circuit diagram
- Homemade C3355 transistor 1km FM transmitter circuit diagram
- LM3914 drives 20 LED light-emitting columns circuit diagram
- Konka lc-tm2008 LCD color TV video decoding circuit diagram
- Digital tachometer circuit diagram based on magnetic sensor design
- Telephone off-hook indicator circuit diagram
