Simple music control lantern circuit diagram
Source: InternetPublisher:aerobotics Keywords: Lantern circuit circuit diagram music control Updated: 2021/12/10
With the connections shown in the figure, the audio voltage can be divided through the transformer to trigger the triac, causing the lights to glow alternately according to the strength of the music signal. When in use, just connect the two ends of the potentiometer directly to the two ends of the radio speaker.
ck="window.open(this.src)" alt="Click to see larger image" />
- How to use FPGA and RS485 for industrial communication
- Methods to reduce mutual coupling between antenna elements
- FM transmitter in a matchbox
- MAX2360/MAX2362/MAX2364 I/Q 2000~1700 MHz/1000~800 MHz dual-band
- MCl3175/MCl3176 FM/AM 928~902 MHz/470~260 MHz Transmitter
- XE1203 FSK 915/868/433 MHz Transceiver
- TR5100 FM 150~15 MHz transceiver
- TX500 ASK 1 GHz~100 MHz Transmitter Module
- RF2516 AM/ASK/OOK 433/315 MHz Transmitter
- MICRF500 FSK 1000~700 MHz Transceiver
- LM567 decoding alarm circuit diagram
- Circuit diagram of a voltage doubler rectifier electronic ballast
- Tube crossover balanced inverter circuit diagram
- Simple level conversion circuit diagram
- Car power supply voltage monitoring circuit diagram
- Household small TV transmitter circuit diagram
- AC grid powered light emitting diode circuit diagram
- Sound-activated circulating lantern circuit
- Music control lantern circuit
- Circular lantern circuit
