Remote control light wireless transmitter circuit diagram
Source: InternetPublisher:qoistoochee128 Keywords: Wireless transmitter circuit diagram remote control light coding Updated: 2021/08/14
In the figure, V1, C3, C1, L1, and L2 form a 100MHz high-frequency oscillator. Adjusting C4 can adjust the oscillation frequency. Generally, C4 uses a fine-tuning capacitor with an adjustment range of 3 to 18pF.
The antenna is a printed antenna made on a printed circuit board. 100MHz radio waves are emitted by this antenna. The encoded signal of QCH417 is output from DOUT and sent to the base modulated radio wave emission of V1 through R6.
SB1~SB8 are remote control keys. Press any one of them, and the three output terminals of SR830 will output a set of codes. At the same time, Vdd will change to 12V, Vcc will change to 5V, and QCH417 will start to work and transmit the code. The three-digit code generated by SR830 is sent to the A9 to A11 terminals of QCH417 and is also used as coding information, so that the transmission code of each button is different, that is, each button can only control one control object.
ck="window.open(this.src)" alt="Click to see larger image"/>
- TA8164P FM Radio
- Circuit principle and production of six-tube radio
- A cheap and easy-to-make infrared TV signal repeater
- U3742BM ASK/FSK 433.92/315 MHz Receiver
- Radio coding transmission circuit composed of MICRF102 and PT2262
- Cordless phone transmitter circuit
- GPS RF front-end circuit composed of MX2740
- nRF903 GMSK/GFSK 950~430 MHz transceiver
- DKIOOOT OOK 315 MHz Transmitter Module
- RCV420 4~20mA Precision Current Loop Receiver
- As a qualified engineer, you need to remember these circuit diagrams throughout your life!
- Mobile phone production of remote home appliance remote control circuit diagram
- One-digit display timer circuit diagram
- 220V welding machine wiring circuit diagram
- Motorcycle ignition circuit diagram
- Household small TV transmitter circuit diagram
- Night target display circuit diagram
- Hitachi RAS-5102 inverter air conditioner remote control transmitter circuit diagram
- Programmable multi-compound fast charging circuit diagram
- Battery fast charging control integrated circuit diagram
