A stepper motor and its driving principle circuit diagram
Source: InternetPublisher:smallembedded Keywords: Power DC/DC Updated: 2021/11/23
Stepper motor is an open-loop control element stepper motor device that converts electrical pulse signals into angular displacement or linear displacement. Under non-overload conditions, the motor's speed and stopping position only depend on the frequency and number of pulses of the pulse signal, and are not affected by load changes. When the stepper driver receives a pulse signal, it drives the stepper motor according to the The set direction rotates at a fixed angle, called "step angle", and its rotation runs step by step at a fixed angle.
Stepper motor is one of the most commonly used control components in industrial control and instrumentation. It has the characteristic that the input pulse is proportional to the rotation of the motor shaft. It is widely used in intelligent robots, floppy disk drives, and data machine tools. Microcomputer control of stepper motors is most suitable. The system is designed to use the 20BY-0 model stepper motor, which is suitable for +5V DC power supply, the step angle is 18 degrees, and the motor coil is composed of four phases. The figure below shows a stepper motor and its driving principle circuit diagram.
![A stepper motor and its driving principle circuit diagram](http://www.eeworld.com.cn/circuit/upload/c278747d776c9b25b7e33afe00b92163/c33ccc2c6306942692a1ddf13efd241e.jpg)
- TPS274C65 helps reduce downtime and increase productivity in 24 VDC power distribution plants
- 220V Remote Load Monitor
- Step-down power supply for driving relays
- Basic connection circuit of signal and power supply composed of ISOll3
- Isolated two-wire current loop circuit (XTR101, ISO100)
- LED Driver ZD1680
- LNK304 non-isolated LED light string driver circuit
- 3~15V 10A adjustable voltage regulated power supply
- USB power socket using the car battery
- Practical constant current charger-----Constant current charger
- Importance of Voltage Supervisors and Output Topology Selection
- DC output DC converter circuit
- Clock switching circuit and its precautions
- Circuit diagram for using an ordinary TV remote control to control switches of other home appliances such as light bulbs and fans
- Uninterruptible power supply circuit diagram composed of MIC5158
- Power circuit of STR5412
- Signal simulator circuit diagram
- Dual-purpose voice-activated switch circuit diagram
- Three-way DC-DC converter circuit
- Computer motherboard power circuit with +5.1V, -5V, +12V and -12V outputs
